Cisco ASA5505 and 2 internet sources
Jan 25th, 2010
I have 2 internet providers. How can set ASA
so on interface 0 I will have provider #1 with interface IP 192.168.1.1
and on Interface 1 provider #2 with interface IP 192.168.1.2
Then I'd like to have 5 computers with gateway 192.168.1.1 and another 5 with gateway 192.168.1.2
Is it possible ?
I know ASA offers just simple failover not load balancing like some cheap routers but I don't want failover just 2 gateways.
sachinraja Mon, 01/25/2010 - 14:12
Hi Adam
Im a bit confused here. Would the 5 PCs on the same broadcast domain as internet router, and still pass through ASA ?? Its good to have firewalls do blocking on layer 3 !
Anyways, with regards to your question, you need to have ASA configured on multicontext mode to do effective load balancing.. with normal licenses, its tough to do load sharing, as the scenario you gave... you do can have dual default gateways on ASA, but the exact scenario you gave with 5 PCs pointing to one router, and 5 PCs onto a different router is not possible through ASA.. If you dont need ASA's, you can put the PC's directly on layer 2 with the router...
Raj
walank2004 Mon, 01/25/2010 - 14:22
Currently I have Cisco ASA5505 connected to T1 provider and
simple SMC router/firewall connected to Comcast.
T1 -> port0 ASA5505 -> port 2 LAN switch (ASA port2 IP 192.168.1.1) - 5 computers have this as a gateway.
Comcast-> SMC -> same LAN switch (SMC internal IP 192.168.1.2) - other 5 computers have this as a gateway.
I want to dispose SMC router and have ASA5505 to do the same job.
Hope this will clerify my original question.
Panos Kampanakis Mon, 01/25/2010 - 14:23
Or the ASA can run at layer 2, by being in transparent.
Routed mode makes it a L3 hop, and transparent makes it a bridge that firewalls.
I hope it helps.
PK
