No internal tone when picking up phone (7965G)
Answered Question
Jan 25th, 2010
Good evening,
     My boss wanted me to resurrect an old function that we had on our old analog system. We had a certain number for IS Emergency calls that was on every IS Department members phone. He wanted me to make a 2nd line on each phone with that number. It did not have to have voice mail - it was a purely a company internal number. I created the 2nd DN on several IS Dept IP phones including mine. It works great. When someone calls the number it rings on all of the phones that I added.
     The problem is that now when I pick up my phone I hear nothing. If I press the New Call softkey I get tone (internal). I am used to dialing my number first and then picking up the phone and having it dial. Now when I do that I get an earlier call number. I can hit NewCall and enter the number and it works just fine. Incoming calls seem to have no problems.
     I am using Call Manager 7.1.3.10000-11. I have all new 7965G's (I have some 7945G's also but none in IS). This is a fairly new installation and my first CCM to administer ( thus the rookie question). What have I done to myself?
Thanks for any and all help - I appreciate it.
RI
Correct Answer by Rob Huffman about 7 years 5 months ago
Hi RI,
Excellent question here. Have a look at this setting;
Always Use Prime Line = **Set this to False for your scenario
I'm guessing that it is currently set @ True
Description
After you configure the Always Use Prime Line setting in Cisco Unified Communications Manager Administration, when the phone is idle (off hook) and receives a call on any line, the primary line gets chosen for the call.
Tip To configure the Always Use Prime Line feature in previous releases of Cisco Unified Communications Manager, you configured the Always Use Prime Line service parameter for the Cisco CallManager service. In Cisco Unified Communications Manager 6.1(3), you can configure the Always Use Prime Line setting for devices and device profiles.
Cisco Unified Communications Manager Administration Configuration Tips
When you configure this feature, going off hook makes only the first line active, even when a call rings on another line on the phone; that is, the call does not get answered on that line. In this case, the phone user must choose the other line to answer the call.
For more configuration considerations, see Table 4.
GUI Changes
The Always Use Prime Line setting displays in the following windows in Cisco Unified Communications Manager Administration.
System > Service Parameters (for Cisco CallManager service)
Device > Phone
Device > Common Phone Profile
Device > Device Settings > Default Device Profile
Device > Device Settings > Device Profile
Tip If you configure the Always Use Prime Line setting in the Service Parameter, Common Phone Profile, and in the Phone Configuration window, Cisco Unified Communications Manager uses the configuration from the Phone Configuration window.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_3/cucmbe-rel_note-613.html#wp471834
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 01/26/2010 - 06:50
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi RI,
Description
GUI Changes
Device > Phone
Hope this helps!
Rob
ROBERT ISAACS Thu, 01/28/2010 - 14:01
Thanks Rob, I appreciate it. It was the "always use prime line setting". When the site was installed we had no multiple line phones and the consultant didn't change that setting.
thanks again,
RI
