VS-S720-10G Card (6509-E)
Jan 25th, 2010
What is the ASIC acceptable Temparature range for the VS-S720-10G  card? Please check the current temparature range seen :
BRASWSTA01
Temparature recorded :
module 5 outlet temperature: 39C
  module 5 inlet temperature: 25C
  module 5 device-1 temperature: 30C
  module 5 device-2 temperature: 32C
  module 5 asic-1 temperature: 57C
  module 5 asic-3 temperature: 40C
  module 5 asic-4 temperature: 55C
  module 5 RP outlet temperature: 31C
  module 5 RP inlet temperature: 31C
  module 5 EARL outlet temperature: 32C
  module 5 EARL inlet temperature: 26C
module 5 power-output-fail: OK
  threshold #1 for module 5 power-output-fail:
    (sensor value != 0 ) is system minor alarm
module 5 insufficient cooling: N/A
  threshold #1 for module 5 insufficient cooling:
    (sensor value != 0 ) is system major alarm
module 5 fan-upgrade required: N/A
  threshold #1 for module 5 fan-upgrade required:
module 5 outlet temperature: 38C
  threshold #1 for module 5 outlet temperature:
    (sensor value >= 70C) is system minor alarm
  threshold #2 for module 5 outlet temperature:
    (sensor value >= 85C) is system major alarm
  threshold #1 for module 5 inlet temperature:
    (sensor value >= 65C) is system minor alarm
  threshold #2 for module 5 inlet temperature:
    (sensor value >= 80C) is system major alarm
  threshold #1 for module 5 asic-1 temperature:
    (sensor value >= 90C) is system minor alarm
  threshold #2 for module 5 asic-1 temperature:
    (sensor value >= 105C) is system major alarm
  threshold #1 for module 5 asic-3 temperature:
    (sensor value >= 95C) is system minor alarm
  threshold #2 for module 5 asic-3 temperature:
    (sensor value >= 110C) is system major alarm
  threshold #1 for module 5 asic-4 temperature:
  threshold #2 for module 5 asic-4 temperature:
Reza Sharifi Mon, 01/25/2010 - 18:52
  • Cisco Designated VIP,
    2017 LAN
Hello Deepa,
Was this switch upgraded from a regular 6500 to 6500-E?, if yes the fan trays need to be replaced.
What is the temperature in the room where the switch is sitting?
Reza
d.muralidharan Mon, 01/25/2010 - 18:56
The temparature of the room(data center) is fine. Also, there was no upgrade done earlier. Please check the below output as well:
SWITCH#sh idprom module 5 detail
IDPROM for module #5
IDPROM image:
  (FRU is 'Supervisor Engine 720 10GE')
IDPROM image block #0:
  block-signature = 0xABAB, block-version = 3,
  block-length = 160, block-checksum = 6117
  *** common-block ***
  IDPROM capacity (bytes) = 512  IDPROM block-count = 3
  FRU type = (0x6003,0x3FD)
  OEM String = 'Cisco Systems, Inc.'
  Product Number = 'VS-S720-10G'
  Serial Number = 'SAD1151053V'
  Manufacturing Assembly Number = '73-11539-02'
  Manufacturing Assembly Revision = 'B0'
  Manufacturing Assembly Deviation = ''
  Hardware Revision = 2.0
  Manufacturing bits = 0x0  Engineering bits = 0x0
  SNMP OID = 9.12.3.1.9.29.133
  Power Consumption = -540 centiamperes    RMA failure code = 0-0-0-0
  CLEI = COUCADTCAA
  VID = V02
  *** end of common block ***
IDPROM image block #1:
  block-signature = 0x6003, block-version = 2,
  block-length = 103, block-checksum = 3149
  *** linecard specific block ***
  feature-bits =  0x00000000 00000000
  hardware-changes-bits =   0x00000000 00000002
  card index = 254
  mac base = 0017.944A.A72C
  mac_len = 8
  num_processors = 0
  epld_num = 6
  epld_versions = 0003 0003 0002 0001 0002 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000
  port numbers:
    pair #0: type=31, count=02
    pair #1: type=61, count=01
    pair #2: type=60, count=02
    pair #3: type=00, count=00
    pair #4: type=00, count=00
    pair #5: type=00, count=00
    pair #6: type=00, count=00
    pair #7: type=00, count=00
  sram_size = 0
  sensor_thresholds =
    sensor #0: critical = 85 oC, warning = 70 oC
    sensor #1: critical = 80 oC, warning = 65 oC
    sensor #2: critical = -127 oC (sensor present but ignored), warning = -127 oC (sensor present but ignored)
    sensor #3: critical = -127 oC (sensor present but ignored), warning = -127 oC (sensor present but ignored)
    sensor #4: critical = -128 oC (sensor not present), warning = -128 oC (sensor not present)
    sensor #5: critical = -128 oC (sensor not present), warning = -128 oC (sensor not present)
    sensor #6: critical = -128 oC (sensor not present), warning = -128 oC (sensor not present)
    sensor #7: critical = -128 oC (sensor not present), warning = -128 oC (sensor not present)
  max_connector_power = 1650
  cooling_requirement = 35
  ambient_temp = 55
  *** end of linecard specific block ***
IDPROM image block #2:
  block-signature = 0x6008, block-version = 1,
  block-length = 72, block-checksum = 1189
  *** sensor auxiliary block ***
  num_sensor: 4
  reserved: 0
  sensor_thresholds =
    sensor #0 (major: 105, minor: 90) :
    sensor #1 (major: -128, minor: -128) :
    sensor #2 (major: 110, minor: 95) :
    sensor #3 (major: 110, minor: 95) :
  *** end of sensor auxiliary block ***
End of IDPROM image
d.muralidharan Mon, 01/25/2010 - 22:58
Please find the inventory output details:
SWITCH#sh inventory
NAME: "WS-C6509-E", DESCR: "Cisco Systems Catalyst 6500 9-slot Chassis System"
PID: WS-C6509-E        ,                     VID: V04, SN: SMG1133N6BP
NAME: "WS-C6K-VTT-E 1", DESCR: "VTT-E FRU 1"
PID: WS-C6K-VTT-E      ,                     VID:    , SN: SMT1115K855
NAME: "WS-C6K-VTT-E 2", DESCR: "VTT-E FRU 2"
PID: WS-C6K-VTT-E      ,                     VID:    , SN: SMT1115K876
NAME: "WS-C6K-VTT-E 3", DESCR: "VTT-E FRU 3"
PID: WS-C6K-VTT-E      ,                     VID:    , SN: SMT1115K687
NAME: "CLK-7600 1", DESCR: "OSR-7600 Clock FRU 1"
PID: CLK-7600          ,                     VID:    , SN: SMT1105H306
NAME: "CLK-7600 2", DESCR: "OSR-7600 Clock FRU 2"
NAME: "1", DESCR: "WS-X6748-GE-TX CEF720 48 port 10/100/1000mb Ethernet Rev. 2.6"
PID: WS-X6748-GE-TX    ,                     VID: V02, SN: SAL1133XHFL
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 1", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAL1134YJJ8
NAME: "2", DESCR: "WS-X6748-GE-TX CEF720 48 port 10/100/1000mb Ethernet Rev. 2.6"
PID: WS-X6748-GE-TX    ,                     VID: V02, SN: SAD113403JU
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 2", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAL1134YC54
NAME: "4", DESCR: "WS-X6748-GE-TX CEF720 48 port 10/100/1000mb Ethernet Rev. 2.6"
PID: WS-X6748-GE-TX    ,                     VID: V02, SN: SAL1134Y31Q
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 4", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAL1135Z20L
NAME: "5", DESCR: "VS-S720-10G 5 ports Supervisor Engine 720 10GE Rev. 2.0"
PID: VS-S720-10G       ,                     VID: V02, SN: SAD1151053V
NAME: "msfc sub-module of 5", DESCR: "VS-F6K-MSFC3 MSFC3 Daughterboard Rev. 1.0"
PID: VS-F6K-MSFC3      ,                     VID:    , SN: SAD115106E7
NAME: "VS-F6K-PFC3C Policy Feature Card 3 sub-module of 5", DESCR: "VS-F6K-PFC3C Policy Feature Card 3 Rev. 1.0"
PID: VS-F6K-PFC3C      ,                     VID: V01, SN: SAD115103ME
NAME: "7", DESCR: "WS-X6724-SFP CEF720 24 port 1000mb SFP Rev. 2.6"
PID: WS-X6724-SFP      ,                     VID: V02, SN: SAD113309S9
NAME: "WS-F6700-CFC Centralized Forwarding Card sub-module of 7", DESCR: "WS-F6700-CFC Centralized Forwarding Card Rev. 4.0"
PID: WS-F6700-CFC      ,                     VID: V05, SN: SAL1134YMHD
NAME: "8", DESCR: "WS-X6708-10GE CEF720 8 port 10GE with DFC Rev. 1.3"
PID: WS-X6708-10GE     ,                     VID: V03, SN: SAL1125S4CX
NAME: "WS-F6700-DFC3C Distributed Forwarding Card 3 sub-module of 8", DESCR: "WS-F6700-DFC3C Distributed Forwarding Card 3 Rev. 1.0"
PID: WS-F6700-DFC3C    ,                     VID: V01, SN: SAL1132WY5G
NAME: "Te8/1", DESCR: "10Gbase-SR Te8/1"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT112901Q5
NAME: "Te8/2", DESCR: "10Gbase-SR Te8/2"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT112901TX
NAME: "Te8/3", DESCR: "10Gbase-SR Te8/3"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT1129023L
NAME: "Te8/4", DESCR: "10Gbase-SR Te8/4"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT112901QG
NAME: "Te8/5", DESCR: "10Gbase-SR Te8/5"
PID: X2-10GB-SR        ,                     VID: V02 , SN: ONT11290261
NAME: "9", DESCR: "WS-SVC-NAM-2 8 ports Network Analysis Module Rev. 4.3"
PID: WS-SVC-NAM-2      ,                     VID: V05, SN: SAD1124060J
NAME: "WS-C6509-E-FAN 1", DESCR: "Enhanced 9-slot Fan Tray 1"
PID: WS-C6509-E-FAN    ,                     VID: V03, SN: DCH11251947
NAME: "PS 1 WS-CAC-6000W", DESCR: "AC power supply, 6000 watt 1"
PID: WS-CAC-6000W      ,                     VID: V04, SN: AZS11290TA2
NAME: "PS 2 WS-CAC-6000W", DESCR: "AC power supply, 6000 watt 2"
PID: WS-CAC-6000W      ,                     VID: V04, SN: AZS11290TAB
krishnakumarr Mon, 01/25/2010 - 22:46
hi
pl find the link for VS-s720-10G operating temp and requirements
Fan Tray and Minimum Power Supply Required
• E Chassis supports Cisco Virtual Switching Supervisor Engine 720
• 2500W AC or DC
• Non E Chassis requires the following:
• High-speed fan
• 2500W AC or DC
Environmental Conditions
• Operating temperature: 32 to 104°F (0 to 40°C)
• Storage temperature: -40 to 158°F (-40 to 70°C)
• Relative humidity, operating, noncondensing: 10 to 90%
• Relative humidity, nonoperating, noncondensing: 10 to 95%
• MTBF: Demonstrated 85,000 hours
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/product_data_sheet0900aecd806ed759_ps2797_Products_Data_Sheet.html
d.muralidharan Mon, 01/25/2010 - 22:59
I did go through this. But I am not able to get the details for ASIC temparature.
Check the below output as well:
SWITCH#  sh idprom module 5 detail
IDPROM image:
  CLEI = COUCADTCAA
  VID = V02
  card index = 254
  mac_len = 8
  num_processors = 0
  epld_num = 6
  port numbers:
  sram_size = 0
  sensor_thresholds =
  ambient_temp = 55
  num_sensor: 4
  reserved: 0
  sensor_thresholds =
End of IDPROM image
