01-25-2010 10:09 PM - edited 03-19-2019 12:21 AM
Good Day,,,
Can I use one stand alone MCS server, to install Unity 4.2 (Voice Messaging - Non-Failover), and at the same time, install AD and Exchange 2003 (On Windows 2003 of course) which will be integrated with for the use of Unity 4.2?
In the Guide provided by Cisco, it says that you have to use Exchange 2003 on a separate server (partner server), but in Cisco Unity 4.2 System Requirements Guide, it tells you for Voice Messaging solution, you can use the same server.
The Solution will serve 100 users whom are licensed to have a voicemail.
Well, unfortunately, I did install AD, Exchange 2003 and Unity 4.2 on the same server, but I found many errors appearing. So I want to check whether it can be done or not.
Please, if any one can clarify this point
Thank you
AT
Solved! Go to Solution.
01-27-2010 09:19 AM
What you are talking about is voicemail only. Voicemail only can work either way. You can have the Exchange 2003 and AD on the same server or on a seperate server and still be considered voicemail only. Having it on the same server with Exchange and AD is supported and should easily support 100 users. Can you expand on what errors you are experiencing?
Thanks!
Tray
01-27-2010 12:54 AM
Any Help Guys?
01-27-2010 09:19 AM
Thanks!
Tray
01-27-2010 07:37 PM
Many thanks to you Tray.
I had finished the installation earlier but it didn't work, Event Viewer showed many errors.
I started from the scratch, almost after each step I was checking the Event Viewer, which - before installing the Unity - showed some errors, and it found to be related to DNS and Group Policy.... after solving those problems, Unity worked well.
Thank God, everything is working now... All, AD, Exchange 2003 and Unity 4.2(1) is working on one server....
Again, thank you
