Peer group config. in a Route reflector
Answered Question
Jan 25th, 2010
  • Bronze, 100 points or more
Dears ,
I'm trying to configure peer group in one of my PE router (which is working as a route reflector )
I applied the below config. Now I want to bring the IP 172.16.14.2 and 172.16.14.3 as route reflector clients ,but I'm getting below error
(config-router-af)#neighbor 172.16.12.2 route-reflector-client
% Invalid command for a peer-group member
router bgp 65000
bgp log-neighbor-changes
neighbor internal peer-group
neighbor internal remote-as 65000
neighbor internal update-source Loopback1
neighbor 172.16.14.2 peer-group internal
neighbor 172.16.14.3 peer-group internal
address-family vpnv4
neighbor internal send-community extended
neighbor 172.14.14.2 activate
neighbor 172.14.14.3 activate
Before applying peer-group config ,my config. was as given below .Also whether the config. "neighbor 172.14.14.2 activate" is needed under vpnv4 ? .If i remove this neighbor going down and at the same time I can't put something like ""neighbor internal activate"
neighbor 172.16.14.2 route-reflector-client
neighbor 172.16.14.2 send-community extended
neighbor 172.16.14.2 activate
I will rate the helpful inputs
Hari
Correct Answer by jcozzupoli about 7 years 3 months ago
Hari,
Here are some sample configs, this should be what you're after:
RR Configs:
router bgp 65000
neighbor
internal peer-group
neighbor
neighbor
address-family ipv4
  neighbor internal send-community both
  neighbor internal route-reflector-client
  neighbor internal next-hop-self
  no auto-summary
  no synchronization
exit-address-family
exit-address-family
RRC Configs:
router bgp 65000
neighbor Route_Reflector peer-group
neighbor Route_Reflector remote-as 65000
neighbor Route_Reflector update-source Loopback0
neighbor 172.14.14.1 remote-as 65000
neighbor 172.14.14.1  peer-group RouteReflectorPG
address-family ipv4
  no synchronization
  neighbor Route_Reflector send-community both
  neighbor Route_Reflector next-hop-self
  neighbor 172.14.14.1 activate
  no auto-summary
exit-address-family
exit-address-family
Here are the references on CCO (formerly UniverCD):
Assigning Clients to a Peer Group:
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_bgp3.html#wp1015335
Creating a Peer Group:
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_bgp3.html#wp1015489
http://www.cisco.com/en/US/docs/ios/iproute_bgp/configuration/guide/irg_basic_net_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1056201
As you can see, all the answers are a search away!
Joe.
Overall Rating: 5 (1 ratings)
Correct Answer
jcozzupoli Tue, 01/26/2010 - 01:06
Hari,
RR Configs:
router bgp 65000
neighbor
internal peer-group
neighbor
neighbor
address-family ipv4
  no auto-summary
  no synchronization
exit-address-family
exit-address-family
RRC Configs:
router bgp 65000
address-family ipv4
  no synchronization
  no auto-summary
exit-address-family
exit-address-family
Joe.
Haris P Tue, 01/26/2010 - 01:50
Dear Joe ,
Thanks for the config.
I done the same thing .and it's working.
Also in my case all my peer-group membors should be in vpnv4 addressfamily. ,so i wish to configure like "neigh internal   activate" under vpn4 . Is it possible ? Or  whether i need to type "neighbor x.x.x.x activate for all membors ?  .
regards
jcozzupoli Tue, 01/26/2010 - 02:16
Hi Hari,
You need to specifiy the neighbor by IP to activate. As per basic Peer-Group configurations, the use of the peer groups make its more efficient and easier to maintain any BGP attibute manipulation of multiple neighbors to just the one peer-group command, so all you have to do is activate that neighbor under the AF for it to take part in that peer-group and what is configured for that peer-group to do.
Joe.
Haris P Fri, 01/29/2010 - 23:42
I rated it , becose u deserved it
