Ctrl + Break sequence not working
Answered Question
I can not get the switch into rommon mode with the Ctrl + Break sequence, any suggestions? It's a 3512 switch. I just reset the password on another 3512 with no problem. ??
Correct Answer by Ganesh Hariharan about 7 years 3 months ago
Check out the below link for password recovery on cisco switches series
http://www-tss.cisco.com/eservice/compass/common/activities/password_cat_2950.htm
Ganesh.H
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Tue, 01/26/2010 - 05:34
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Ganesh.H
