a problem with the bandwidth utilization filter in the Topology View
Jan 26th, 2010
The customer has configured RMON using CM on all switches in the network. When I tried to use the bandwidth filter in the topology view for high utilization (76-100)% - the links with small utilization are filtered. Here is an example of one links which is marked as high utilized in the Topology View:
interface GigabitEthernet4/6
switchport mode trunk
rmon collection history 21 owner campusmanager buckets 10 interval 300
Entry 21 is active, and owned by campusmanager
Monitors ifEntry.1.21 every 300 second(s)
Requested # of time intervals, ie buckets, is 10,
  Sample # 2042 began measuring at 1d03h
   Received 1051636071 octets, 1562161 packets,
   27295 broadcast and 34512 multicast packets,
   0 undersized and 0 oversized packets,
   0 fragments and 0 jabbers,
   0 CRC alignment errors and 0 collisions.
   # of dropped packet events is 0
   Network utilization is estimated at 140
  Sample # 2043 began measuring at 1d03h
   Received 1298880964 octets, 1803781 packets,
   26504 broadcast and 59229 multicast packets,
   Network utilization is estimated at 63
  Sample # 2044 began measuring at 1d03h
   Received 1299131249 octets, 2044214 packets,
   26656 broadcast and 70204 multicast packets,
   Network utilization is estimated at 64
  Sample # 2045 began measuring at 1d03h
   Received 1480519518 octets, 2117077 packets,
   26366 broadcast and 57120 multicast packets,
   Network utilization is estimated at 112
  Sample # 2046 began measuring at 1d03h
   Received 1072373018 octets, 1598950 packets,
   30611 broadcast and 47075 multicast packets,
   Network utilization is estimated at 3
  Sample # 2047 began measuring at 1d03h
   Received 1197494661 octets, 1747580 packets,
   27028 broadcast and 88612 multicast packets,
   Network utilization is estimated at 36
  Sample # 2048 began measuring at 1d03h
   Received 999134336 octets, 1528403 packets,
   26258 broadcast and 45532 multicast packets,
   Network utilization is estimated at 126
  Sample # 2049 began measuring at 1d04h
   Received 1277686463 octets, 1837673 packets,
   26667 broadcast and 73821 multicast packets,
   Network utilization is estimated at 58
  Sample # 2050 began measuring at 1d04h
   Received 1109721861 octets, 1608105 packets,
   26822 broadcast and 44897 multicast packets,
   Network utilization is estimated at 13
  Sample # 2051 began measuring at 1d04h
   Received 1047859853 octets, 1539916 packets,
   25927 broadcast and 62217 multicast packets,
   Network utilization is estimated at 139
So there is the maximum value 1,4% utilization no between 76 - 100% utilization.
See the interface statistics:
GigabitEthernet4/6 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 000b.5fbb.c47b (bia 000b.5fbb.c4
7b)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 2/255, rxload 3/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is SX
  output flow-control is off, input flow-control is on
  Last input 00:00:00, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 508819
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 15215000 bits/sec, 2511 packets/sec
  5 minute output rate 11209000 bits/sec, 2416 packets/sec
     44788091362 packets input, 51745134980839 bytes, 0 no buffer
     Received 359010927 broadcasts (64939786 multicast)
     14790 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     42781664957 packets output, 45757459531444 bytes, 0 underruns
     0 lost carrier, 0 no carrier
It seems that CM doesn't diveded RMON statistics by 100:-( The customer uses LMS3.2, CM 5.2.1 on Windows 2008 64bit Standard Server. It is without ACS integration. Thank you for your help.
