Catalyst 6500 L2 over IPSEc
Jan 26th, 2010
Is catalyst 6500 supports L2TPv3 over IPSEC in combination with  VPN Services Port Adapter (VSPA) ?
Is catalyst 6500 supports VPLS over IPSEC in combination with  VPN Services Port Adapter (VSPA) ?
Overall Rating: 5 (1 ratings)
Idan Grinshpon Tue, 01/26/2010 - 23:28
Can you describe the traffic flow, please? When IPSEC encapsulation of GRE tunnel performed & how "GRE encapsulated traffic" redirected to VSPA  from SIP-400/600??
Edison Ortiz Wed, 01/27/2010 - 08:37
The VPN SPA will take care of any IPSec related services hence removing this load from the CPU or any other ASIC on the switch.
The SIP400 with a GigaSPA will take care of the physical traffic leaving the switch.
I highly suggest you become familiar with the hardware and configuration so please read the documentation:
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/install_upgrade/6500series/sipspahw.html
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/6500series/sipspasw.html
Idan Grinshpon Wed, 01/27/2010 - 08:58
Where encapsulation of MPLS traffic to GRE tunnel performed? On VSPA or GigaSpa ?
If the answer "On VSPA" - so the output of VSPA is regular IP packet (non MPLS) so why I need GigaSpa WAN card, can't i use LAN card (like 6748) ???
Or you mean that the MPLS packet encapsulated in GRE tunnel on GigaSpa and then IPSEC encapsulated on VSPA ??
Edison Ortiz Wed, 01/27/2010 - 09:05
MPLS is performed on the GigaSPA.
You can use a regular line card as the one you mentioned but it won't support VPLS
And before you ask, EoMPLS over GRE is not supported on 6500.
