SNMP OID query
Jan 26th, 2010
Not sure if this is the right forum for this.....
Doing a bit of work using SNMP for various things - need to know if there is a way to delete the VLAN.DAT file using SNMP - and if so what is the OID I need to use.
Joe Clarke Tue, 01/26/2010 - 16:27
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can use the CISCO-FLASH-MIB for this.  You would set the following objects:
ciscoFlashMiscOpEntryStatus     : 5
ciscoFlashMiscOpDestinationName : "flash:vlan.dat"
ciscoFlashMiscOpCommand         : 3
ciscoFlashMiscOpEntryStatus     : 1
The file should then be deleted.
