CCM 7 Security Password
Answered Question
Jan 26th, 2010
I've been given two possible CCM security passwords for a cluster.
No one is sure which one is the correct one. Is there any way to test the passwords? Or do I need to do
a reset on them?
Jon
Correct Answer by Brandon Buffin about 7 years 3 months ago
Jon,
     The only way I know of to test the password is to install a new node and see if it works. You can, however, reset the password. See the following link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_1/cucm-rel_note-611b.html#wp267177
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Related Content
