CCA ITSP XML TEMPLATE for StarView Solutions
Jan 26th, 2010
Per the documentation, here is the information required to create an XML template for StarView Solutions as an ITSP:
Name of ITSP:  StarView Solutions
Display Proxy Server (Primary) field:  Yes
Display Registrar Server field:  No
Display Outbound Proxy Server field:  Yes
Display Digest Authentication (Username / Password):  No
ITSP SIP TRUNK PARAMETERS
Voice Codec: G.711ulaw, G.729
Fax protocol: T.38, G.711 fallback
RFC2833 (DTMF) payload type:  101
Should UC500 register all DIDs to ITSP: N/A
Is SIP registration for DID(s) using same username / password or unique username / password per DID:  N/A
Please let me know if you need anything else.
Thanks!!!
