01-26-2010 08:21 AM - edited 03-03-2019 05:50 AM
I'm Working on cisco QPM server. I finished all the configuration processes in workflow but when I launch the Monitoring service (in order to have a view of all configurations deployed on devices), an errors messages appears (attached files).
May Someone has already encountered this issue, what could be the reason? The soft is QPM 4.1.
Thanks alot for your response.
Miradoo
Solved! Go to Solution.
02-02-2010 07:40 PM
Opened a TAC case for this issue. It is a known bug with BUG ID of CSCsw80246. The fix is to upgrade QPM to a newer version. 4.1.1 will suffice.
chris
02-01-2010 01:21 PM
I'm also getting the same errors.
02-02-2010 07:40 PM
chris
02-09-2010 12:13 AM
Hi Chris,
Thank you for your response and advice. Upgrading it to a higher version has solved the issue. Now it's running well. I used the 4.1.2 version.
Miradoo
