Need to create a 2-4 km Point to Multipoint Bridge connections
Jan 26th, 2010
I have attached a drawing with shows exacly what i want to do and the distances in each side. If i want to go 802.11n is aironet 1500 the only one that can cover those areas or is there another solution. If not, i will go 1300 and traditional b/g. Seccond question, do i need 4 ap's and 4 directional antenas or is there another solution. And last what antenas and what ap's should i choose for what i have in mind. Thanks in advance
gamccall Wed, 01/27/2010 - 06:05
  • Silver, 250 points or more
"If i want to go 802.11n is aironet 1500 the only one that can cover those areas or is there another solution. If not, i will go 1300 and traditional b/g."
I don't believe Cisco has released any 802.11n bridging hardware. The 1250 has commands to set a bridge mode but this is not recommended or supported by Cisco. For the time being your options are the 1300 (g) or the 1400 (a).
"Seccond question, do i need 4 ap's and 4 directional antenas or is there another solution."
Based on your diagram, you need 5 APs, 4 directional, and one omni.
"And last what antenas and what ap's should i choose for what i have in mind."
My recommendation would usually be to use 1400s rather than 1300s, simply because you're much less likely to encounter contention/noise in the 5GHz space. If you want to use the 1300s for cost reasons, definitely do a careful survey.
Peter Nugent Wed, 01/27/2010 - 11:03
  • Cisco Employee,
The 1250 is now supported for bridging, originally it wasn't and I can show you two documents where one says yes the other says no.
I am not sure what restrictions there are as its a while since I looked at this. Most people who set it up before it was approved for bridging were successful.
This says yes
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6973/ps8382/prod_qas0900aecd806b7c82_ns767_Networking_Solutions_Q_and_A.html
This says No
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c1.html
I assume the second doc is just older.
Leo Laohoo Wed, 01/27/2010 - 13:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I can assure you that Point-To-Point Bridge is supported on the 1250 is you are using 12.4(21a)JA1.  I have it setup here right now.  Unfortunately I had to raise a TAC request because the Cisco documentation (Document ID #68087) is incorrect.
