Quick Anyconnect question
Jan 26th, 2010
  • Green, 3000 points or more
Hi All,
Just a quick question....
Can I use the Anyconnect client to connect via VPN to a Windows 2008 Server?
The Windows Server runs 64-bit OS, therefore we cannot use the normal Cisco VPN Client, is the anyconnect the solution, or it only works with ASAs and IOS?
Thank you!
Federico.
Edit... If I want machines connecting to a Windows 2008 Server, can I use the Anyconnect VPN client or if not, I have to use L2TP/IPsec or what's the best way to go?
