Customized webauth redirect to favorites tabs
Jan 26th, 2010
Hi!
I´m trying to create a Customized WebAuth page for WLC 5.0. The dilemma is that customers that have several tabs that starts different webpages at start of the webbrowser would like to have those tabs redirected to the chosen startpage for every tab after login. As it is now the customized webauth appears on every tab and when You try to hit the update buttom on the webbrowser a popupmessagebox appear with the notice that Your already logged in. Instead of that message I would like to be redirected to the appropriate website chosen for that specifik tab. Hope You understand the dilemma and that there are someone that have an answer to share. How do I configure the customized "Login.html" to achieve the desired act?
Peter Vahlersvik
Trending Topics - Security & Network
