PEAP with ACS 5.1
luciano01
I configured PEAP (EAP-MSCHAPv2) with user on Active Directory on ACS 5.1 and works fine.
I need help to configure the PEAP and EAP-TLS using certificates. My Certification Authority is on Microsoft's Active Directory. Can someone help me? Thank you.
Jatin Katyal
Here are the documents helping out the configuration of EAP-TLS:
EAP-TLS Version 1.01 Configuration Guide
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a008068d45a.shtml
AACS 5.1 EAP-TLS:
http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_secure_access_control_system/5.1/user/guide/eap_pap_phase.html#wp1029217
Please let me know if you have any questions.
JK
Plz rate helpful posts-
~Jatin
So for the configuration of PEAP, whit ACS 5.1 and Windows 2003 Active Directory, I need this:
1. Configure the external database, Active Directory.
2. Import the certificate file (*.cer)  downloaded from the CA.
Yes, if you are using external user database then first you need to join/integrate ACS with AD.
Since you are using peap; you can either install the self signed certificate or CA certificate, go through the following link for detailed description on how add certificate.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/user/guide/admin_config.html#wp1052640
You can follow the below link in order to configure Peap authentication.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/user/guide/admin_config.html#wp1067000
Jatin
Do rate helpful posts~
~Jatin
