AP frequently association and disassociation
Jan 26th, 2010
We have an WLC 4402 running 5.2.157 code and WCS 5.2. AP1131 & 1142 is using in our environment.
In our environment, we find that there are frequent AP association and disassociation events in the WCS.
Usually association event will come up after a few minutes of the disassociation event.
From the trap log in the WLC, I could see the following
AP 'XXX', MAC: XXX disassociated previously due to AP Reset. Last reboot  reason: power loss
and some message is like that
AP 'XXX', MAC: XXX disassociated previously due to AP Reset. Last reboot reason: operator changed 11g mode
Any Idea on that ???
ibm.alexl Tue, 01/26/2010 - 19:24
I have some difficulties in upgrading to a major release (Not technical issue)
Is there any configuration / work around could solve the problem???
Thanks.
Leo Laohoo Thu, 01/28/2010 - 18:12
I've seen happen when I used to run 5.x firmware.  When I upgraded to 6.X everything went away.
bchaltraw Fri, 01/29/2010 - 15:56
I too am having this issue, I am running a WiSM with 6.0.188.0.  The AP will connect then say %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(CAPWAP_ECHO_REQUEST) and reboot.
Was suggested by TAC to do two simatanious captures.  That's interesting to setup with a all Fiber 6500 and no copper available.  Come on, there has to be something to this. I have been reading this same issue all over the place. My AP is one switch away from my core, no interface drops or errors, and the AP is dropping 5 packets and the AP goes POOF?
Just doesn't make sense..
