Spanning Tree network unstable
Answered Question
Jan 26th, 2010
I'm using rapid-pvstp in my fiber ring and here is problem: i have to main sites, A and B, and a chain of 30
switches from site A to site B, for the main site A i have the vlan 11 and for the main site B the vlan 12, the
switch closer to site A is configured to be the root of vlan 11 and the switch closer to site B is configured
to be the root of vlan 12, the problem that i have is that the network is very unstable, the root bridge is
changing from the right one to other one very often (sometimes every second) and that is causing me that some
ports sometimes are in blocked state and a second later in forwarding state and then blocked again.
It looks that the switches that are far away from the root of each vlan are not
receiving the bpdu or they receive them with bad values so they start to make them self roots or choosing
another root, doing some researching i found this: "When a BPDU propagates from the root bridge toward the
leaves of the tree, the age field increments each time the BPDU goes though a bridge. Eventually, the bridge
discards the BPDU when the age field goes beyond maximum age. If the root is too far away from some bridges of
the network, this issue can occur. This issue affects convergence of the spanning tree."
http://www.cisco.biz/en/US/tech/tk389/tk621/technologies_tech_note09186a00800951ac.shtml#awkward
What
I was thinking is to modify the hello, forward and max age timers on the root switches (root for vlan 11
and root for vlan 12) but i'm not sure what value should i use in each timer.
Any other ideas??
Here i attach the diagram for in order to have a better idea of the scenario.
Thanks in advance for your help!
Correct Answer by Giuseppe Larosa about 7 years 5 months ago
Hello Alfonso,
your calculations are good.
Anyway I would simply use
hello = 1 sec
max-age= 40 sec
This should give margin also for the chain scenario where one link is broken
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 01/26/2010 - 11:17
  • Hall of Fame,
    Founding Member
Hello Alfonso,
you can consider the max-age time as a sort of TTL for the STP BPDU
max-age / hello frequency gives you how far BPDUs are considered valid
so you may need to increase max-age and to reduce hello interval to achieve an higher ratio so that BPDUs can travel correctly
You need to consider what can happen when a failure changes the ring in a long chain (worst case)
This has been discussed in some previous threads
Hope to help
Giuseppe
alfonso.cornejo Tue, 01/26/2010 - 11:46
Hi Giusepe,
Right know i have the default Hello 2 sec, Max age 20 and Forward 15, do you think this values can do the job:
Hello 2 sec
Max age 40
Forward 15
???? or is there a formula to calculate them???
I mean because of the fact that i have a chain of like 30 switches
alfonso.cornejo Tue, 01/26/2010 - 12:11
I believe this are the formulas:
End-to-end BPDU propagation delay—This value is the amount of time that is necessary for a BPDU to travel from one end of the network to the other end. Assume a diameter of seven hops, three BPDUs that can be lost, and a hello time of 2 sec. In this case, the formula is:
End-to-end_BPDU_propa_delay
= ((lost_msg + 1) x hello) + ((BPDU_Delay x (dia – 1))
= ((3 + 1) x hello) + ((1 x (dia – 1))
= 4 x hello + dia – 1
= 4 x 2 + 6
= 14 sec•Message age overestimate—The purpose of this parameter is to account for the age of the BPDU since origination. Assume that each bridge increases the BPDU message age by 1 sec. The formula is:
Message_age_overestimate
= (dia – 1) x overestimate_per_bridge
= dia – 1
= 6
max_age
= End-to-end_BPDU_propa_delay + Message_age_overestimate
= 14 + 6
= 20 sec
I'm i correct?
This values only have to be changed on the root switches right? for this case on my actual root sw for vlan 11 and my actual root for vlan 12?
Thanks!
Correct Answer
Giuseppe Larosa Tue, 01/26/2010 - 12:27
  • Hall of Fame,
    Founding Member
Hello Alfonso,
hello = 1 sec
max-age= 40 sec
Hope to help
Giuseppe
alfonso.cornejo Tue, 01/26/2010 - 12:45
Thanks alot Giussepe!
Thanks!
Giuseppe Larosa Tue, 01/26/2010 - 12:51
  • Hall of Fame,
    Founding Member
Hello Alfonso,
yes, sorry for not having noted this
of course configure also on secondary root bridge to have consistency  in case of failure of primary root bridge
Hope to help
Giuseppe
alfonso.cornejo Tue, 01/26/2010 - 12:53
No problem,
I'll perform this configurations tonight and I'll post how it goes.
Thanks again!
alfonso.cornejo Wed, 01/27/2010 - 10:02
Hi Giuseppe,
I did the changes last night and everything is working as it should be!.
Thanks for your help...
