CUPC Automatic Distribution - Registry Update
Jan 26th, 2010
Is there a way to automatically populate login server information and different default settings when installing CUPC 7.0(2)?  It would make distribution of the software much easier if we could package the install with a registry update.
Please let me know...
Thanks.
Overall Rating: 4 (1 ratings)
Jonathan Schulenberg Tue, 01/26/2010 - 11:29
  • Cisco Designated VIP,
    2017 IP Telephony
As far as I can tell, the CUPC 7.0 client stores this in an XML file wthin the user's profile.
C:\Users\\AppData\Roaming\Cisco\Unified Personal Communicator is the path for Vista and 7 machines.
The uclocal.xml appears to be the default file. You might be able to copy a generic form of this into the directory using a login script but be careful not to overwrite one if it already exists. Also make sure the user retains change/full permission on the file.
