Redirect HTTP traffic to HTTPS on CSM
Answered Question
Jan 26th, 2010
  • Bronze, 100 points or more
Greetings,
Does anyone know how to redirect HTTP traffic to HTTPS when using CSM and SSL?
Mohamad
Correct Answer by Sean Merrow about 7 years 3 months ago
Hi Mohamad,
I've seen this done in slightly different ways.  One way is at the very bottom of the following examples from the Cisco.com CSM-S config guide:
CSM-S Configuration Examples
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/csms/2.1.1/configuration/guide/cfgxpls.html
Another way is like this:
serverfarm REDIRECT
  nat server
  no nat client
   redirect-vserver REDIRECT
    webhost relocation https://www.example.com/
    inservice
serverfarm SSL_DC
  no nat server
  no nat client
  real 192.168.78.36 local
   inservice
vserver VSERVER_80
  virtual 192.168.78.35 tcp 80
  serverfarm REDIRECT
  persistent rebalance
  inservice
vserver VSERVER_443
  virtual 192.168.78.35 tcp 443
  serverfarm SSL_DC
  inservice
Hope this helps get you started.
Sean
Overall Rating: 5 (1 ratings)
Correct Answer
Sean Merrow Fri, 01/29/2010 - 06:47
  • Silver, 250 points or more
Hi Mohamad,
serverfarm REDIRECT
  nat server
  no nat client
    inservice
serverfarm SSL_DC
  no nat server
  no nat client
   inservice
vserver VSERVER_80
  serverfarm REDIRECT
  inservice
vserver VSERVER_443
  serverfarm SSL_DC
  inservice
Sean
Mohamad Qayoom Fri, 01/29/2010 - 07:44
Thank you Sean,
I was able to make the redirects works by doing something similar to what you mentioned.
Mohamad
