Deleted Agent on the Webview Reporting
Answered Question
Jan 26th, 2010
   I have deleted the Agent from the UCCE ( agent explore and the agent list on Configuration Manager at AWS ). but Still i could see the agent on the real-time template of the webview reporting. Am i missing some to remove ?
thanks
Correct Answer by Soman Nair about 7 years 4 months ago
This is happening because agent details are still there in your records. A simple select query to t_Agent table can show you the specific agent available in database.
You need to delete it permanently from d/b. But do note that after this, you wouldn't be able to see any historical report for this particular agent.
Configuration Manager > Configure ICM > Administration > Deleted Objects.
Delete the specified agent details permanently from 'Agent' and 'Person'.
Good Luck.
Soman Nair.
(Pls rate if this was helpful)
Correct Answer by shaheeramunir about 7 years 4 months ago
Have you removed the agents from "Deleted Objects" as well? It can be found under "Miscellaneous Tools".
Overall Rating: 0 (3 ratings)
Correct Answer
shaheeramunir Tue, 01/26/2010 - 23:14
Correct Answer
Soman Nair Tue, 01/26/2010 - 23:25
Good Luck.
Soman Nair.
