SPA50XG Extension Dialplan and 911.
Jan 26th, 2010
Hello All,
Okay, here's a wierd one for you. Or, maybe it's just really simple and so am I.
I'm trying to enable 911, and other X11 service number access on our Asterisk system.  We're using all SPA50XG phones with a few SPA942's thrown in here and there.  I have the Asterisk side worked out.  I tested it from an analog extension on an FXS port and all works as planned.  But I can't seem to get the right dialplan configuration on the SPA50XG's.
Here's the Extension 1 dialplan from the SPA509G I'm testing with:
2xx|*2xx|3xx|*3xx|4xx|5xx|*5xx|6xx|*6xx|7xx|*72xx|8xx|9,[2-9]11|9,[2-9]xxxxxx|9,1[2-9]xxxxxxxxx
Everything but x11 works.  If for example I dial 9,811, the phone comes back with "Incomplete Address" in the display and a reorder tone.  I'm watching the Asterisk log as I dial and the dial string never makes it to the switch, it's erroring out at the phone.
I'll read through the manual tonight, but I was hoping someone else had run into this and might be able to tell me what I'm doing that's making my phones so unhappy with me.
Michael
Alberto Montilla Wed, 01/27/2010 - 04:26
  • Cisco Employee,
Dear sir;
Few questions.
- Is the same dial plan used on SPA9XX, does it work?
- Did you upgrade the unit to latest firmware 7.4.X?
- Can you collect syslog on the phone to see what the debug message (level 3)?
- Please try this dial plan:
([2-8]xx|*[235-8]xx|*72xx|9,[2-9]11|9,[2-9]xxxxxx|9,1[2-9]xxxxxxxxx)
Regards;
Alberto
cityofwalsenburg Wed, 01/27/2010 - 07:23
Alberto,
I will try this on the SPA942 this afternoon and report back.
All of the SPA509G and 504G phones are running 7.4.3 and the SPA942 phones are running 6.1.5(a).
I will collect the syslog output and forward it to you.
I know my dialplan could have been a little better!  The extension list has grown organically and we haven't had a chance to put the change control request through to shorten them.
As a side note, I played around last night after I posted this and found that the following dialplan still gives me the same error:
2xx|*2xx|6xx|*6xx|9,x11
Again, the dial string never even makes it through to the Asterisk server.
Michael Sheldon
cityofwalsenburg Wed, 01/27/2010 - 09:22
Alberto,
I am using an SPA509G this morning with 7.4.3.
First, I tried using the string that I sent in my original message:
2xx|*2xx|3xx|*3xx|4xx|5xx|*5xx|6xx|*6xx|7xx|*72xx|8xx|9,[2-9]x11|9,[2-9]xxxxxx|9,1[2-9]xxxxxxxxx
As soon as I dialed 9,811 the phone locked up hard and required a power cycle.
This is the syslog capture from that attempt:
Jan 27 09:03:03 cowalse-np-06 System started: [email protected], reboot reason:H0
Jan 27 09:04:37 cowalse-np-06 Soft key XML service, URL = url=http://xx.xx.xxx.xx/phonedir/index.php
Jan 27 09:04:37 cowalse-np-06 Soft Key XML service finalize URL = http://xx.xx.xxx.xx/phonedir/index.php
Jan 27 09:04:37 cowalse-np-06 +++ need tftp addr..
Jan 27 09:04:37 cowalse-np-06 [0]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:04:37 cowalse-np-06 [1]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:04:37 cowalse-np-06 [2]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:04:37 cowalse-np-06 [3]Reg Addr Change(0) 0:0->c0a81021:5060
Jan 27 09:04:37 cowalse-np-06 +++ send scaps discovery query
Jan 27 09:04:53 cowalse-np-06 ++++ retry query scaps
Jan 27 09:04:53 cowalse-np-06 +++ need tftp addr..
Jan 27 09:04:53 cowalse-np-06 +++ send scaps discovery query
Jan 27 09:05:19 cowalse-np-06 ++++ retry query scaps
Jan 27 09:05:19 cowalse-np-06 +++ need tftp addr..
Jan 27 09:05:19 cowalse-np-06 +++ send scaps discovery query
Jan 27 09:06:05 cowalse-np-06 ++++ retry query scaps
Jan 27 09:06:05 cowalse-np-06 +++ need tftp addr..
Jan 27 09:06:05 cowalse-np-06 +++ send scaps discovery query
Jan 27 09:07:11 cowalse-np-06 ++++ retry query scaps
Jan 27 09:07:11 cowalse-np-06 +++ need tftp addr..
Jan 27 09:07:11 cowalse-np-06 +++ send scaps discovery query
Jan 27 09:08:16 cowalse-np-06 ++++ retry query scaps
Jan 27 09:08:16 cowalse-np-06 +++ need tftp addr..
Jan 27 09:08:16 cowalse-np-06 +++ send scaps discovery query
Next, I applied your dialplan string:
The first number I tried was 9,811, the phone locked as soon as I dialed the last digit.
The second number I tried was 9,411 with the same result.
The syslog capture doesn't show anything, but here it is anyway:
Jan 27 09:51:10 cowalse-np-06 System started: [email protected], reboot reason:H0
Jan 27 09:52:44 cowalse-np-06 Soft key XML service, URL = url=http://xx.xx.xxx.xx/phonedir/index.php
Jan 27 09:52:44 cowalse-np-06 Soft Key XML service finalize URL = http://xx.xx.xxx.xx/phonedir/index.php
Jan 27 09:52:44 cowalse-np-06 +++ need tftp addr..
Jan 27 09:52:44 cowalse-np-06 [0]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:52:44 cowalse-np-06 [1]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:52:44 cowalse-np-06 [2]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:52:44 cowalse-np-06 [3]Reg Addr Change(0) 0:0->c0a81021:5060
Jan 27 09:52:44 cowalse-np-06 +++ send scaps discovery query
Jan 27 09:52:50 cowalse-np-06 CC_switchOnAudDev(3)
Jan 27 09:53:00 cowalse-np-06 ++++ retry query scaps
Jan 27 09:53:00 cowalse-np-06 +++ need tftp addr..
Jan 27 09:53:00 cowalse-np-06 +++ send scaps discovery query
Jan 27 09:54:16 cowalse-np-06 System started: [email protected], reboot reason:H0
Jan 27 09:55:50 cowalse-np-06 Soft key XML service, URL = url=http://xx.xx.xxx.xx/phonedir/index.php
Jan 27 09:55:50 cowalse-np-06 Soft Key XML service finalize URL = http://xx.xx.xxx.xx/phonedir/index.php
Jan 27 09:55:50 cowalse-np-06 +++ need tftp addr..
Jan 27 09:55:51 cowalse-np-06 [0]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:55:51 cowalse-np-06 [1]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:55:51 cowalse-np-06 [2]Reg Addr Change(0) 0:0->c0a8fa0e:5060
Jan 27 09:55:51 cowalse-np-06 [3]Reg Addr Change(0) 0:0->c0a81021:5060
Jan 27 09:55:51 cowalse-np-06 +++ send scaps discovery query
Jan 27 09:56:07 cowalse-np-06 ++++ retry query scaps
Jan 27 09:56:07 cowalse-np-06 +++ need tftp addr..
Jan 27 09:56:07 cowalse-np-06 +++ send scaps discovery query
Finally, I moved onto the SPA942 with the 6.1.5(a) firmware.
and set the debug level to 3.  This time the phone did come back with the 'Address Incomplete'
error in the display and the reorder tone.  The dial string never made it to Asterisk.
Below is the syslog capture:
Jan 27 10:02:33 cowalse-np-08 ++++ retry query scaps
Jan 27 10:02:33 cowalse-np-08 +++ need tftp addr..
Jan 27 10:02:33 cowalse-np-08 +++ send scaps discovery query
Jan 27 10:03:02 cowalse-np-08
Jan 27 10:03:13 cowalse-np-08 last message repeated 3 times
Jan 27 10:04:01 cowalse-np-08 +++ need tftp addr..
Jan 27 10:04:01 cowalse-np-08 [0]Reg Addr Change(0) 0:0->c0a81021:5060
Jan 27 10:04:01 cowalse-np-08 +++ send scaps discovery query
Jan 27 10:04:17 cowalse-np-08 ++++ retry query scaps
Jan 27 10:04:17 cowalse-np-08 +++ need tftp addr..
Jan 27 10:04:17 cowalse-np-08 +++ send scaps discovery query
Jan 27 10:04:31 cowalse-np-08
Jan 27 10:04:42 cowalse-np-08 last message repeated 3 times
Jan 27 10:04:43 cowalse-np-08 ++++ retry query scaps
Jan 27 10:04:43 cowalse-np-08 +++ need tftp addr..
Jan 27 10:04:43 cowalse-np-08 +++ send scaps discovery query
Jan 27 10:04:54 cowalse-np-08
Jan 27 10:04:58 cowalse-np-08 last message repeated 2 times
Jan 27 10:05:05 cowalse-np-08
Jan 27 10:05:29 cowalse-np-08 ++++ retry query scaps
Jan 27 10:05:29 cowalse-np-08 +++ need tftp addr..
Jan 27 10:05:29 cowalse-np-08 +++ send scaps discovery query
Jan 27 10:06:29 cowalse-np-08 lcd brightness: 0x23(35)
Jan 27 10:06:35 cowalse-np-08 ++++ retry query scaps
Jan 27 10:06:35 cowalse-np-08 +++ need tftp addr..
Jan 27 10:06:35 cowalse-np-08 +++ send scaps discovery query
Jan 27 10:07:39 cowalse-np-08 +++ need tftp addr..
Jan 27 10:07:39 cowalse-np-08 [0]Reg Addr Change(0) 0:0->c0a81021:5060
Jan 27 10:07:39 cowalse-np-08 +++ send scaps discovery query
Jan 27 10:07:48 cowalse-np-08
Jan 27 10:07:54 cowalse-np-08 last message repeated 5 times
Jan 27 10:07:55 cowalse-np-08 ++++ retry query scaps
Jan 27 10:07:55 cowalse-np-08 +++ need tftp addr..
Jan 27 10:07:55 cowalse-np-08 +++ send scaps discovery query
Jan 27 10:08:04 cowalse-np-08
Jan 27 10:08:21 cowalse-np-08 ++++ retry query scaps
Jan 27 10:08:21 cowalse-np-08 +++ need tftp addr..
Jan 27 10:08:21 cowalse-np-08 +++ send scaps discovery query
Let me know if there is anything else you'd like me to try.
Michael Sheldon
