Problem with Specific Model? Lenovo R500 - Any Ideas?
Jan 26th, 2010
I have 6 Wism WLC's with 900 APs.
Technicians in building A had no problems connecting clients to WLAN-1 with WPA2-PSK (AES) on most laptops.  However they could not connect any R500 laptops.  They would not get past DHCP.
I moved all the Access Points in that building to a different controller and they started working.  The WLAN config is from a template so it should be the same.  I check the Interfaces on both controllers and they look the same.
I had suspected problems with this particular controller before hence the reason I moved the APs off of it while troubleshooting.  Do you think it could be a bad controller?
What else could I look for.  It seems so odd to affect only one model of laptop?
