CSS11506 can not be accesed - urgent help
Answered Question
Jan 26th, 2010
Greeting
my CSS11506 (version 08.10.2.05) can not be accessed both ssh and console, but it can be pinged.
when first time the problem occured, I had reboot the machine and I could access for about two days. And than the problem comes back,
now, it looks very two days, the system need reboot. I have login to the system and there is no error, no core file.
so, I have tried to force a dumping by using killer ping, but there is still no core file.
Could I have some tip where is the dumping information located? and how can I access it?
and
Could I have some help on how can I troubleshoot this problem? and if possible, how can I fix it?
Any comments will be apprecaited
Thanks in advance
julxu
Correct Answer by Gilles Dufour about 7 years 3 weeks ago
if the killer ping is done correctly the box should crash and automatically generate a core file during reboot which is
saved in the core directory.
Try maybe an upgrade to a more recent image.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Tue, 02/02/2010 - 01:04
Gilles.
