Valcom V-2001a
Neal haas
Level 3
Level 3
I see some posts about getting the Overhead paging to work with Valcom v-2001a but I dont see the answers. I know I need an FXO port and thought that we did everything correctly. But it just does not work.
Does anyone have the configuration that I need to do. We are creating a MGCP FXO port
Thank you
dellison
The Valcom V-2001A will work with the FXO port using MGCP.  Configuration instructions are posted on the Valcom website at http://www.valcom.com/techsupport/ip_solutions/config-guides.htm .  The instructions should work for all of the Valcom page controllers that use a loop-start trunk port, both single-zone and multi-zone controllers.  If additional info is needed, the Valcom Technical Support department can be reached at support[at]valcom.com, or 1-800-valcom1.
Valcom also provides a full line of SIP-enabled speakers and gateways, which can interoperate with the legacy equipment.  See the full line at www.valcom.com.
Full disclosure: this reply is being made by Valcom Technical Support.
Thank you.
