L2L Vpn. tunnel is up but no routing between sites.
JORGE RODRIGUEZ Tue, 01/26/2010 - 21:24
your nat exempt rule does not reflect your crypto map access list in your asa5505 office2 configuration
you have
access-list outside_cryptomap_1 extended permit ip
crypto map outside_map 1 match address outside_cryptomap_1
your current  nat inside statement is : nat (inside) 0 access-list nonat
change the nat exempt  rule to :  nat (inside) 0 access-list outside_cryptomap_1
try those changes and post results.
pudawat Thu, 01/28/2010 - 16:13
The VPN confguration seems to be fine.Can you send the debugs from the firewalls.
debug crypto isakmp 200
debug crypto ipsec 200
try to add the command "sysopt connection permit vpn" on both the ASA
Related Content
