WAAS product license is missing
Jan 26th, 2010
I just checked on my WAAS console and realize that there is a critical error for license is missing for few of the WAAS devices, is anyone know what kind of license is needed? Only some of the devices having this error the rest are fine.
Appreciate any advice or comment for this issue. Thanks.
Eric Rose Wed, 01/27/2010 - 05:57
  • Cisco Employee,
Depending on how you configured the devices initially. the setup script would ask you for the license level that you have.
Otherwise you will have to install the license level yourself.
here is the url to configure it via the GUI you can also do it via the CLI "license add..." or "license clear..."
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v413/configuration/guide/other.html#wpmkr1052752
Table 9-1     WAAS Software Licenses
License
Description
Transport
Enables basic DRE, TFO, and LZ optimization. Cannot be configured if the Enterprise license is configured.
Enterprise
Enables the EPM, HTTP, MAPI, NFS, SSL, CIFS (WAFS), and Windows Print application accelerators, the WAAS Central Manager, and basic DRE, TFO, and LZ optimization. Cannot be configured if the Transport license is configured.
Video
Enables the video application accelerator. Requires the Enterprise license to be configured first.
Virtual-Blade
Enables the virtualization feature. Requires the Enterprise license to be configured first.
Eric
     if this answer your question please mark as answered with a 5.
wooiboontan Sun, 02/07/2010 - 23:42
I have verified with Cisco and these is a bug for version 4.1.3a f
irmware which caused the licensing issue so upgrade to 4.1.5c will resolve this problem.
Anyway, thanks for your comment.
