Maximum keepalives of this type have been exceeded
rustamovea
I got this erroron my CSS 11503:"%% Maximum keepalives of this type have been exceeded. Cannot activate"
Cisco says that:
CSCek46451 - If you attempt to modify a configured service or global keepalive, you may incorrectly receive the message "%% Maximum keepalives of this type have been exceeded. Cannot activate" when the maximum number has not been exceeded. This message may occur when you configure a global keepalive and add the global keepalive to a service. Later, you change the global keepalive type to type tcp. After you activate the keepalive or it is modified dynamically when the global keepalive is already active, the internal keepalive count is corrupted. This problem may cause any further service or global keepalive modifications to fail with the previously-described error message.
How can I solve this issue without upgrading software of CSS 11503? Current version 8.10
You have 8.10(1.06) and the problem has been fixed in 8.10(2.05)
You need to upgrade to the latest 8.10 version which is 8.10(6.02).
After that the problem will be solved.
Gilles
11 Replies 11
Marko Leopold
There is a limit of keepalives to configure. Limit depends on type of keepalive. Class A and class B. Type in "sh keepalive-summary brief" and you see your maximum. Changing firmware will not extend the limits.
CISCOCSS# sh keepalive-summary brief
KEEPALIVES:  System Maximum - 2048
  Class A (ICMP, TCP, HTTP-head non-persistent, SSL):          MAX - 2048
  Class B (FTP, HTTP-Head persistence, HTTP-Get, Scripted):    MAX -  512
                  Maximum    Configured    Remaining      Permitted
Class A:            2048             5         2043           2028
    ICMP:            2048             2         2046           2028
     TCP:            2048             3         2045           2028
     SSL:            2048             0         2048           2028
    HTTP:            2048             0         2048           2028
Class B:             512            15          497            497
     FTP:             256             0          256            256
    HTTP:             256            15          241            241
  Script:             256             0          256            256
    Use Output:       (16)          ( 0)         (16)           (16)
System(A+B):        2048            20         2028           2028
Keepalive States:  Alive   Dying   Down   Suspended   No-Services
                      13       0      5           0             0
I have only 8 Configured Keepalives Class A on my CSS!
Hello!
Can you provide your configuration? And maybe the output of the command above.
Marko
Ganesh Hariharan
Cisco says that:
Keep alives can be changed as per the requirement if you dont want to upgarde to higher version as per the above bug id,check out the below link hope it will clear your query !!
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v7.40/command/reference/CmdKeepC.html
Ganesh.H
The number of my keepalives don't reach limit of 2048.
CSS11503# sh keepalive-summary
Keepalives:
AUTO_nexthop00001                State: Alive          10.0.139.254
AUTO_PRDWEB1-CRMWEB01            State: Alive          10.0.139.120
AUTO_PRDWEB2-CRMWEB02            State: Alive          10.0.139.121
AUTO_UATWEB1-CRMWEBTST01         State: Alive          10.0.139.140
AUTO_UATWEB2-CRMAPPTST03         State: Alive          10.0.139.146
AUTO_DIAMOND-WEB01               State: Down           10.0.139.97
AUTO_DIAMOND-WEB03               State: Alive          10.0.139.11
AUTO_DIAMOND-WEB02               State: Alive          10.0.139.98
AUTO_DIAMOND-WEB04               State: Alive          10.0.139.11
AUTO_NTP-Redundancy01            State: Alive          10.0.139.17
AUTO_NTP-Redundancy02            State: Alive          10.0.139.18
Option brief doesn't available.
service DIAMOND-WEB03
  ip address 10.0.139.11
  keepalive port 3333
  keepalive type tcp
  active
I have about 10 such kind of services.
I think the problem is in modificaton keepalive type dynamically when the global keepalive is already active, the internal keepalive count is corrupted. This problem may cause any further service or global keepalive modifications to fail with the previously-described error message.
rustamovea
P.S. I can add keepalive type tcp, but can't keepalive type ICMP.
If is any other solution?
8.10 is not the full version....could you please give us the exact version ....
The problem has been fixed in
Software Version 8.10.2.05 Resolved Caveats
Thanks.
Gilles:
rustamovea
CSS11503# show version
Version:               sg0810106 (08.10.1.06)
Flash (Locked):        08.10.1.06
Flash (Operational):   08.10.1.06
Type:                  PRIMARY
Licensed Cmd Set(s):   Standard Feature Set
CVDM Version:          cvdm-css-1.0
Gilles
Thank you Gilles!
