Upgrade 6.5.3-007 to 6.5.3-014
Jan 27th, 2010
Hi everyone !
I seem to be having trouble upgradring from 6.5.3-007 to 6.5.3-014...
I did it all correctly, disconnected from the cluster, stoppped the listeners and deliveries, and then launched the upgrade from the Command Line.
I'm stuck at this point :
Upgrades available.
1. AsyncOS 6.5.3 build 014 upgrade For Email, 2009-12-14
[1]> 1
Performing an upgrade may require a reboot of the system after the upgrade is ap
done. Do you wish to proceed with the upgrade? [Y]>
Removing stale lock file
IronPort Email Security Appliance(tm) Upgrade
Finding partitions... done.
Setting next boot partition to current partition as a precaution... done.
Erasing new boot partition... done.
Installing application...
Nothing seems to happen...
A reboot obviously solves it and brings me back to build 007 ... but I'm wondering why this upgrade seems to be failing ??
Any clue ?
By the way, I couldn't find any definitive release notes for this build... Maybe I should just avoid it and wait for Async OS 7 ?
Cheers !
Fred
frederic.lens Wed, 01/27/2010 - 04:23
Hi Ronan,
Thanks for the feedback.
I tried a third time to install the upgrade... and it failed again (stuck again at the same stage), so I guess I will be logging a support incident tommorrow.
Will let the community know of the outcome
Cheers
Fred
VeNoMouSNZ Wed, 01/27/2010 - 13:35
I upgraded 2 C350's to 014 last night with no issues.
rokeeffe265 Wed, 01/27/2010 - 03:16
Hi Fred,
I just upgraded one of our boxes (same versions you mention) there and experienced no trouble at all.
Installing application... done.
Installing CASE... done.
Installing Sophos Anti-Virus... done.
Reinstalling AsyncOS...     done.
...so on, so forth
I don't get the 'removing stale lock file' message though at the begining of the process though.
I'd be inclined to log a support ticket at this stage.
frederic.lens Thu, 01/28/2010 - 02:57
Thanks to the quick and efficient support of Ironport, my 2 appliances have been upgraded this morning.
The upgrade process was running into a time-out at a certain moment.
The support engineer disabled unneeded system processes and the upgrade went fine
I suggest that people running into the same kind of issue open a support ticket
Have a nice day!
Fred
pvdberg00 Fri, 01/29/2010 - 04:59
Is there a need for upgrading to this version. Otherwise I suggest to wait untill version 7 is released (feb 2010)
Peter
frederic.lens Tue, 02/23/2010 - 02:46
Dear all,
Just to keep you posted on this issue. I have been experiencing the same problem when trying to upgrade to v7 so I did some testing...
I had a proxy server defined for all updates... which we thought might be causing the problem.
And indeed it was ! proxy removed and voilà !! Upgrades are working again !
Happy upgrading !
Fred
(proxy details : SQUID 2.7 + Websense 7.1 + Trend Micro IWSS 3.1 Patch 1122)
