Authorization per device
Jan 27th, 2010
I want to authorized user in Cisco ACS per network devices added in Cisco ACS 4.2. My theme is to give full access on device-1 and read-only access on device-2 to same user. Kindly guide me to do this.
jauhar1980 Wed, 01/27/2010 - 04:21
Yes, I am using Window Active Directory as a external database for authentication
Jatin Katyal Wed, 01/27/2010 - 05:12
Hi Atif,
You can assign Shell Auth. Sets at the user,group or NDG level.More details are mentioned on the following link:
You need to create two command set, one for "Read-only access" and other for " Full access"
Full access:
Read-only access:
Once you are done with command set after that edit the user/group setup > Jump to shell command authorizatio section
Look for the third option "Assign a Shell Command Authorization Set on a per Network Device Group Basis"
And there you can select the NDG's and command set > submit and restart.
Please make sure that you have all the required command authorization on the device.
Plz rate helpful posts-
