SIP Trunk IPCelerate Call Recording
Jan 27th, 2010
I require some assistance.  My setup is:  Verizon SIP Trunk----CUBE-----(H323)CM4.1.
Off of this I have some IP Phones that I need to record calls via IPCelerate.  IPCelerate tells me that they can only record in G729a or G711u.
My trunk uses MTP and Outbound Fast Start.  How can I do one of the following:
1.  Setup CUBE to use a transcoder to merge a g711 stream from the IP Phone to a g729 stream to Verizon.  Normally this scenario comes to play when integrating VM Servers that do not support g729, but in this case it is the phone that I want to invoke the transcoder, however, how can I force it to invoke the transcoder when it can do g729 natively.
2.  Setup my trunk to do end to end g729a.  I have not been able to find a good document on the CUBE configuration for this part.  How do I force G729a to be in the SDP out to the SBC when that really is not a selectable codec?  I tried changing the codec complexity on the voice-card, but that did not seem to work.
Any help on this would be appreciated.
Thank you.
Related Content
