Interface BVI and G.SHDSL
Jan 27th, 2010
Hi all,
Today i setup the link via Interface V.35 with encap frame-relay, i used Interface BVI instead of Serial Interface but it not work. i can't ping to provider gateway but router shown me everything is up (Interface and line protocol). I asked to provider he said because you use V.35 not G.SHDSL then you couldn't configure BVI. I returned to use Serial Interface that it working properly.
Anyone can clarify/advice me about the relationship of V.35, G.SHDSL and Interface BVI.
Thank in advance
Giuseppe Larosa Wed, 01/27/2010 - 11:52
the question is not V.35 versus SHDSL but how the service is configured and what encapsulation is expected:
bridging over frame relay is possible but it is a different encapsulation from sending IP packets inside a FR frame:
IP over FR =  FR | IP
bridging over FR =  FR | ethernet | IP
if you send the second one and the other device expects the first there is no match.
Hope  to help
