LMS 3.2 - how to reset DFM Database
Answered Question
Jan 27th, 2010
Hey experts,
I want to reset my DFM database, because there are many entries of (now) unmanaged devices.
So how can I do this correctly on LMS 3.2 without touching the other databases.
I found the following thread in this Forum (https://supportforums.cisco.com/message/694414#694414)
It say´s to do the following steps:
Stop the daemons
cd CSCOpx\bin
perl dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
perl dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
perl dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
restart the daemons
Can I use this commands in LMS 3.2, too ?
Anything else to do?
Btw. we use the windows version of LMS 3.2.
thx,
Patrick
Correct Answer by David Stanford about 6 years 11 months ago
In addition to these commands, go ahead and delete or rename the following files:
NMSROOT/objects/smarts/local/repos/icf/DFM.rps
NMSROOT/objects/smarts/local/repos/icf/DFM1.rps
Overall Rating: 5 (1 ratings)
Correct Answer
David Stanford Wed, 01/27/2010 - 07:39
patrick.peuten_2 Thu, 01/28/2010 - 01:02
Hey davistan,
thank you. It worked wonderfully =)
The only thing I had to do after all this steps was to re-install the database access.
The command for this is: \NMSROOT\bin\perl dbaccess.pl install
Summary for all other Users:
net stop crmdmgtd
go to NMSROOT\objects\smarts\local\repos\icf\ and delete the following files ( I even deleted all the other files in this directory )
DFM.rps
DFM1.rps
go to NMSROOT\bin
net start crmdmgtd
go to NMSROOT\bin
Bye,
Patrick
Related Content
