All SA proposals found unacceptable - error message
I am setting up a ASA 5510 to accept remote access IPSEC vpn connection.
After I configure the firewall using the command line, and try using the Cisco VPN Client v5.0.02.0090, it cannot connect.  And when I look at the logg on the firewall, i saw the 'All SA proposals found unacceptable' error message.
Do you know what is the most likely cause of this?
Attached is the firewall log message.
Thanks a lot for your help.
