Wireless LAN Controller and Linksys Wireless G IP phones (WIP310)
Jan 27th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
Hi I am having some difficulty with Roaming between Access points with Linksys Wireless g IPhones (Badged Cisco WIP310) and CallManager on a network using a Wireless LAN Controller (2112 WLC). I have proved that the configuration is ok on the network by using a Cisco 7921G and this works fine when moving between access point when on a call. However the Linksys handsets drop the call if they roam between the AP.
I have had a good look at the settings on the handset but nothing stands out that I can adjust.
Any input would be appreciated.
Richard
