Writing to a XML file
Jan 27th, 2010
I have a script that when you call a CTI RP and either dial 1 or 2 it make a xml file toggle between true and false and then it writes to another file xml file. Somehow when it writes to the file it changes the file name. Has anyone experienced this?
Thanks.
mclenden Sun, 01/31/2010 - 17:07
There are few reasons this would happen...post the script
so we can pin-point the problem.
Abdulbaseer Mohammed Sun, 01/31/2010 - 22:19
  • Silver, 250 points or more
Like the other poster pointed out its hard to pinpoint but following are my vague su
ggestions:
As soon as you have the user select 1 or 2 and goes to that loop copy the results in a filename as copied from one of the pre existing variable.
So you can control the name of file and move on.
