single Global Directory of multiple clusters
Jan 27th, 2010
Hi ...
is there any way that a single global directoy will work for all differnt clusters .... let say i have 3 clusters and i want a single global directoy on all 3 differnt pub .....
kindly share ideas
Jaime Valencia Wed, 01/27/2010 - 19:39
  • Cisco Employee,
  • Hall of Fame,
    2011
If they're all AD integrated, then sync against the same user base. If DCD is used, then you would need to write down your own customized script, put it as the directory URL in all clusters and configure your script to connect to each DCD and look for a user.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
muhammadzubair Thu, 01/28/2010 - 00:23
Dear
its not AD integrated .... do u have any sample script to do soo .... summary is that
3 cluster running in 3 regions ....
1st cluster ---- PUB and Subs ---- 4.3
2nd cluster ----PUB --------------------4.2
3rd cluster ----PUB---------------------4.2
Related Content
