DFM3.2/LMS3.2 lots of Unresponsive-Events
Jan 27th, 2010
We cant use DFM3.2/LMS3.2 due to a lot of false-positve Unresponsive-Events. The cause is that a virgin installed DFM polls each found IP-interfaces, that is not administrativly shutdown. This behavior is unuseable for this network, because of some isolated and protected networks not beeing routed to the LMS.
1. Is there a possibility to let DFM availability ping the device management IP's got from DCR only (like in previous DFM versions)?
2. or is there a possibility to can filter out networks for availability ping's in DFM?
Joe Clarke Fri, 01/29/2010 - 17:19
1. DFM will, by default, ping all IP interfaces on a device.  You can go to DFM > Device Management > Device Details, and unmanage those IP addresses which you do not want DFM to ping.  That will greatly reduce those unresponsive events.  Note: you cannot unmanage the device's management IP address.  DFM must always be able to ping this address.
2. See 1.
STEFFEN NEUSER Wed, 02/03/2010 - 01:40
Thx, Joe for this very good hint.
To keep the management IP for polling was not the point. If we can't reach the management IP's, than we would have problems at a very basic level: how to choose management IP's:)
Many thx, Steffen
