01-27-2010 02:26 PM - edited 03-11-2019 10:02 AM
Hi All,
I have the following configuration and I was able to block the ''Farmville'' game of Facebook.
regex blockex1 "/onthefarm"
regex blockex2 "apps\.facebook\.com"
class-map type inspect http match-all block-url-class
match request uri regex blockex1
match request header host regex blockex2
policy-map type inspect http block-url-policy
parameters
class block-url-class
drop-connection log
policy-map global_policy
class inspection_default
service-policy global_policy global
Now, I need to block www.facebook.com
The problem is that I cannot add another ''match request header host regex'' statement under the class, because it gives me an error.
I've tried the following regex but none of them seem to work:
regex facebook-regex "[Ff][Aa][Cc][Ee][Bb][Oo][Oo][Kk].[Cc][Oo][Mm]"
regex domain1 "\.facebook\.com"
Each time, applying the regex with the appropiate command:
no match request header host regex blockex2
match request header host regex facebook-regex
match request header host regex domain1
So, how is the appropiate way to do this?
Thank you!
Federico.
Solved! Go to Solution.
01-27-2010 07:38 PM
Wouldn't it be simpler to just block facebook.com instead of the farmville game on facebook and facebook.com?
-KS
01-27-2010 07:38 PM
-KS
01-29-2010 09:05 AM
I was able to block www.facebook.com, www.twitter.com and www.hi5.com using the following configuration:
regex domainlist1 ".*facebook.*"
regex domainlist2 ".*twitter.*"
regex domainlist3 ".*hi5.*"
class-map type regex match-any DomainBlockList
match regex domainlist1
match regex domainlist2
match regex domainlist3
class-map type inspect http match-all BlockDomainsClass
match request header host regex class DomainBlockList
policy-map type inspect http http_inspection_policy
parameters
class BlockDomainsClass
drop-connection log
Thank you!
Federico.
