multiple advertise map \ conditional statements
santoshdpawar
Hi All,
I guess advertise map under BGP can be used only for a prefix. Is there a way to define multiple conditional advertisements For eg. advertise 10.0.0.0/8 when 172.16.1.2/32 is unavailable + advertise 200.200.200.0/24 when 172.16.1.3/32 + ......
Santosh
Laurent Aubert
Hi Santosh,
Yes it's supported. What is not supported is multiple conditional statement for the same advertise prefix like:
neighbor xxx.xxx.xxx.xxx adtervise-map xxx non-exist-map xxx
neighbor xxx.xxx.xxx.xxx adtervise-map xxx non-exist-map yyy
Laurent.
Hi Laurent,
Thanks. Can you give me an example or a URL with such configuration.
Thanks in advance.
Best regards.......
Here is the template:
neighbor 1.1.1.1 advertise-map aaa non-exist-map bbb
neighbor 1.1.1.1 advertise-map ccc non-exist-map ddd
Each route-map refer to a different prefix.
Laurent.
