CCNP Frame Relay Router config
Jan 27th, 2010
Does anyone have a copy of the frame relay router config that works with the labs in the Cisco Education Courseware ?
I am trying to go through the CCNP exams before the date when the last 2 exams arent offered anymore.
Ron
Overall Rating: 5 (1 ratings)
chris.macleod Thu, 01/28/2010 - 01:33
When I was studying for my BSCI a few months back I used Building Scalable Cisco Internetworks (BSCI): Authorized Self-study Guide (CCNP Self-study) 3rd Edt.
I have attached the lab from the book with the interfaces changed to suit my equipment.  I have also attached the frame relay switch config.  All you should need to do is change the interfaces and map statements as your interfaces will no doubt be different.
johnnylingo Mon, 02/01/2010 - 10:39
Here's my current config from my Frame Relay hub router.  It connects to the spoke router via a T1 crossover cable (pin1 = pin4, pin2 = pin5)
ip cef
frame-relay switching
interface Serial0/0
no ip address
encapsulation frame-relay IETF
service-module t1 clock source internal
service-module t1 timeslots 1-24
frame-relay lmi-type cisco
frame-relay intf-type dce
The commands in BOLD are unique to the hub router.  The spoke should be configured the same, minus these commands.
