CME Outbound calling groups
Jan 27th, 2010
Greetings,
I have a CME system with different groups of extensions and phones.
Extensions 100-105 should use voice-port 0/0/0 - 0/0/3 for outbound calling
Extensions 200-205 should use voice-port 0/1/0 - 0/1/3 for outbound calling
and so on.
Inbound calling configurations I would hope would not be effected (like connection plar).
How do I accomplish this?
David
Overall Rating: 5 (1 ratings)
paolo bevilacqua Thu, 01/28/2010 - 05:11
  • Hall of Fame,
    Founding Member
It is not a trivial configuration, basically requires called number manipulation or COr list applied to ephone DN.
I do not have a compelte config example here, but would be able to provide consultancy if you are interested.
Ovais Iqbal Thu, 01/28/2010 - 05:49
  • Cisco Employee,
You can accomplish this by using the COR list, if you have not worked with cor-lists before then you would need to understand it first otherwise you will end up troubleshooting it for hours.
Example:
You will need to play with Inbound/Outbound assignment of cor lists: In this example here Phone 1 will use the dial-peer 100, phone 2 will use dial-peer 200 and phone 3 can use all of them.
dial-peer cor custom
name pt-portone
name pt-porttwo
name pt-portthree
dial-peer cor list css-portone
member pt-portone
dial-peer cor list css-porttwo
member pt-porttwo
dial-peer cor list css-portthree
member pt-portthree
dial-peer cor list css-phoneone
member pt-portone
dial-peer cor list css-phonetwo
member pt-porttwo
dial-peer cor list css-phonethree
member pt-portone
member pt-porttwo
member pt-portthree
dial-peer voice 100 pots
destination-pattern 9[2-9]..[2-9]......
corlist outgoing css-portone
port 0/0/1:23
dial-peer voice 200 pots
corlist outgoing css-porttwo
port 0/0/2:23
dial-peer voice 300 pots
corlist outgoing css-portthree
port 0/0/3:23
ephone-dn 1 dual-line
cor incoming css-phoneone
ephone-dn 2 dual-line
cor incoming css-phonetwo
ephone-dn 3 dual-line
cor incoming css-phonethree
Hope it helps.
Ovais.
fruition3000 Thu, 03/04/2010 - 22:45
You answered his question and my month long question.  I appreciate the post without the "consultancy" lol.
