Can use SFP-H10GB-CU3M to connect 6120XP to Cat6K Switch?
Jan 27th, 2010
Can use SFP-H10GB-CU3M OR SFP-H10GB-CU5M to connect 6120XP to Cat6K Switch?
ambahl Mon, 02/15/2010 - 02:59
Yes, you can use SFP-H10GB-CU3M to connect 6120XP to Cat 6k, with the help of CVR-X2-SFP10G converter for X2 ports. This converter will convert existing X2 based 10G port on Cisco 6500 to SFP 10G interface.
RomainJean Mon, 05/17/2010 - 07:30
if we don't have this connector, what kind of cable/connector should we use to connect a UCS6100 FI to a cisco switch?
Nuno Filipe Alv... Mon, 05/17/2010 - 07:42
Fiber cable + SFP 10GE on the nexus side and the other end of the fiber + X2 on the 6500 side
Nuno Ferreira
RomainJean Mon, 05/17/2010 - 08:37
Is it compulsory to use a Nexus equipement on the Lan side?
I have a cisco 3750 switch with  4 miniGbic ports, i can't use a UCS SFP+ from the Fiber-Interconnect to the 3750.
Nuno Filipe Alv... Mon, 05/17/2010 - 09:01
You dont have to connect to Nexus equipment. Your LAN can be anything as long as you can connect the UCS system to it.
Currently you need a switch with 10GE ports to uplink from your 6100s.
I believe that in the next version of the firmware/software in UCS you will be able to connect your 6100s to the LAN using 1G ports.
Nuno Ferreira
