WCCP Load Balance
Jan 27th, 2010
Dear Gurus,
How wccp support load balance of multiple cache engine (e.g BC) ? Does the ip wccp group-list command automatically configures it?
I'll be using 6509 with multiple BC as cache engines.
Tia.
Giuseppe Larosa Fri, 01/29/2010 - 12:02
  • Hall of Fame,
    Founding Member
Hello Jeff,
your understanding is correct: the master cache decides how the IP flows of sessions are distributed among the set of web caches and provides info to the router(s)
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/wccp.html#wp1001150
Hope to help
Giuseppe
jeffersoncbriones Fri, 01/29/2010 - 20:58
Hi Guiseppe,
Yes, just created a group list and then it automatically balance to my 2 web cache engine with 50% hash allotment. The odd thing though is that evrytime i check the config on my router the wccp commands are gone though its working. Maybe bec. of the version?
Data-Center-6500#sh version | include image
System image file is "disk0:c6sup22-pk2o3sv-mz.121-20.E"
Thanks.
Jeff
