CTIOS 7.5 Agent Desktop
Jan 27th, 2010
If the agent desktop is minimized when a call is offered to an agent the ctios agent desktop pops up.
Is there a way to turn that feature off so it always stays minimized unless manually brought up?
Overall Rating: 4 (1 ratings)
shaheeramunir Wed, 01/27/2010 - 23:25
I think you can find your required parameters under this path in registry on CTIOS servers:
HKLM_Local_Machine\Software\Cisco System, Inc.\Ctios\CTIOS_Warid\CTIOS1\EnterpriseDesktopSettings\AllDesktops\ScreenPreferences\Name\MainScreen.
I have 7.2 version and hope its same in 7.5
Del H Tue, 02/02/2010 - 14:32
Thanks that was helpful but will not solve my issue.  Your recommendation changes it for every agent.  I only want to affect individual agents.
Thanks for you suggestion though!
Del
Edward Umansky Mon, 02/08/2010 - 19:29
That won't be possible with the out-of-the-box CTIOS toolkit client. You will need to either customize the desktop to allow individual settings or switch to CAD.
