Idea about how to combine 2 separate network but same Network Block
Jan 27th, 2010
Hello
If anyone has done this before or have ideas please share  me youre ideas. We have 2 separate networks and suddenly
decided to implement a capability tthat their voip can call each other  w/o passing thru PSTN. We gonna put a separate
dedicated link (Fiber). But the problem is their using same network 192.x.x.x. I'm thinkin about address tanslation but
kinda tricky for me. Were using CME 4.0 in 3800 series and 4 digits local extension and 7 to the other side.
I really appreciate it if you share youre ideas w/ me. Thanks
pompeychimes Wed, 01/27/2010 - 23:05
  • Bronze, 100 points or more
On each network I'd put the phones on seperate VLAN/Subnet. For example...
Network 1
Workstations 192.168.100.0/24
Phones 192.168.101.0/24
Network 2
Phones 192.168.102.0/24
dantebarlizo Sun, 01/31/2010 - 02:10
Sorry for the late reply.. Not  possible.. i forgot to mention that both network is already
existing and in production. And a lot of their network block is the same. I'm thinking
it's going to be address translation. but very tricky.
pompeychimes Sun, 01/31/2010 - 04:54
Understood. However, with careful planning it wouldn't take much to move the phones over to a new network. To reduce your exposure you could move a few phones at a time. Either way good luck.
dantebarlizo Sun, 01/31/2010 - 07:48
Thanks a lot mate...  That would really work if the current plan is approved w/c is b/w 50 to 100 phones only on each
side that are allowed to call each other.. But I think it's going to be a problem  if they suddenly decide to change it
to all off the phones should be w/c is around estimate of 2000 to 3000 phones of all sides at least. I
