MPLS fail over config
Jan 27th, 2010
We have 2 cisco 1800 routers and we are running EIGRP , we have 2 mpls links for each routers how to configure one mpls link fails automatically takes
2nd link for the productions --Like HSRP
Can any one help on this for configurations
regards
krishna
spremkumar Thu, 01/28/2010 - 08:07
  • Red, 2250 points or more
Hi Krishna
Can you tell me whether you are running eigrp in your lan or in the wan ? can you give more inputs on how the routers are connected internally in local lan?
regds
Mohamed Sobair Thu, 01/28/2010 - 08:16
  • Gold, 750 points or more
Hi Krishna,
Do you mean failover with the service provider on each router? Or do you mean failover between your routers toward each one of the service providers?
Are the Cisco 1800 routers connected? Are you running a routing protocol with the service provider?
If you want to achieve failover like HSRP on a single router towards one of the service provider, then this is controlable by the routing protocol used.
If you want to achieve failover between you routers, if you want one of the 1800 routers takes precedence over the other, then your 1800 has to be connected and is also controlled by the routing protocol configuration.
Please let us know more about your current design and if this achieve your objective
Mohamed
krishnakumarr Thu, 01/28/2010 - 22:46
Thanks for your reply
I need  failover between  routers towards each one of the service providers If one Service provider link is down other link should take over
we are running Eigrp for towords SP
I want achive failover between the routers
Soon I will provide the network digaram in details
regards
krishna
