Telnet issue with error message "%SEC-4-TOOMANY : Box secured, too many options on internal packet"
Jan 28th, 2010
Hi All,
I had issue on telnet.
Recently, I have replaced an old module WS-X6408A-GBIC with new module WS-X6724-SFP for C6505-E core switch.
After replacing, siter FM tried to telnet to remote core switch, but failed with error message as below:
Then I tried to telnet locally, the same error message came out.
The only configurations that I did are to assign some port of the new module to correct vlan.
The information I searched from internet is:
Explanation :  The system was not able to process the packet because there was not enough room for all of the desired IP header options.
                    The packet has been discarded.
Recommended Action :  Change the configuration so that fewer IP header options are stored.
But I have no idea where to start to troubleshoot.
Please help.
Thanks.
laputaxyf
Mohamad Qayoom Wed, 02/17/2010 - 13:50
  • Bronze, 100 points or more
laputaxyf,
Have you tried to console into the switch?
If you can console into the switch, check the CPU utilization byt using "sh process cpu sorted."
Mohamad
Ganesh Hariharan Thu, 02/18/2010 - 00:13
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi All,
Please help.
Thanks.
laputaxyf
Hi laputaxyf,
As per the error cisco says the below information
%SEC-4-TOOMANY:   Box secured, too many options on internal packet
The system was not able to process the packet because there was not enough room for all of the desired IP header options. The packet has been discarded.
Recommended Action: Change the configuration so that fewer IP header options are stored.
and there is No specific documents apply to this error message.
can you post your configuration of your box.
Ganesh.H
Yi Fan XU Thu, 02/18/2010 - 00:54
Hi All,
I have checked.
This issue is a known IOS bug.
To solve the problem, either upgrade the IOS or remove the ip security commands.
Anyway, thanks for the help and information.
laputaxyf
Related Content
