Installing IPCC on a non Cisco Hardware: The registry
Answered Question
Jan 28th, 2010
Hi All;
If I need to install the IPCCE on a non Cisco harware (HP or IBM server), I heared that there is a registry file need to be run that will modify the registry to allow the IPCCE software to be installed on the hardware.
Can anyone advise for this file?
Any help?
Bilal
VMWare allows you to create a virtual Linux box abstracted from the underlying host and you can then insert the CUCM installation DVD and it will install. The host can be running a range of operating systems - I have used Windows XP, Windows 2003 Server and VMWare's own operating system on an ESX server.
The installer knows it's a VMWare abstraction and does not do the normal hardware checks. The process could not be any easier.
There are many blogs out there with movies that guide you through the process of installing. Try this URL and watch the video.
http://www.blindhog.net/how-to-install-call-manager-6x-in-vmware/
Since I just helped a colleague install CUCM 7.x on an ESX 3.5 server today and I found this simple guide to the post-install steps, with a movie you can watch, I'll provide the URL.
http://www.brainbump.net/2008/12/getting-cisco-unified-communications-manager-70-up-and-running-using-vmware/
Geoff
Overall Rating: 5 (2 ratings)
david.macias Thu, 01/28/2010 - 05:16
  • Blue, 1500 points or more
I don't recommend you go this route as when I did it, back in the 3.x days it was tedious and any SR/patch rewrote the registry.  I've hard successful stories of using the Cisco media and installing it on VM.  This is for UCCX, UCM works like a charm under VM.
david
bilalghayad Thu, 01/28/2010 - 14:11
I mean by IPCCE is the IPCC Enterprise which is, actually I need to build a lab for:
Cisco Voice Gateway
Cisco Call Manager
IPCC (ICM + RGR + PG, ...) and IP IVR
About the VMWare, what exactly u mean that VMware will be fine? Does it mean if I used VMWare then I do not need to worry about the hardware requirements? Or it means that the VMWare support the IPCC components (ICM, RGR, PG)?
Any explaination?
Bilal
david.macias Thu, 01/28/2010 - 14:35
ICM will be fine on any server, it has no hardware requirements.  UCM will need to be installed on VM.  IP IVR should also be installed on VM, but you will need to use the Cisco media to do so.
david
bilalghayad Thu, 01/28/2010 - 14:43
What does it means that it needs a cisco media?
About the UCM, it can be installed via VMWare on any server?
Bilal
Correct Answer
Geoff
bilalghayad Tue, 02/02/2010 - 04:54
Thanks a lot, really it helped me a lot.
The remaining thing: If I need to do a LAB for Call Manager, IPCC and CVP and I do not have the CDs, is there any versions that can be downloaded to be used for LAB purposes?
About the license, it come with the CD or it come with the contract?
Bilal
Chad Stachowicz Tue, 02/02/2010 - 10:53
  • Silver, 250 points or more
bigal,
    The short answer is no.  You must have the media to do the base installs for all the products.  Cisco does not offer them for download.  The easiest and cheapest way to get all this if you work for a cisco partner is to apply for the Cisco UC 7.0 or soon 8.0 NFR, which will include all of these products and license.  It costs USD $275, or did for the 7.0 Lab NFR Kit.
HTH,
Chad
