strange switch error message
Jan 28th, 2010
Hi all
My switch() sudden got rebooted and when i checked the syslog/csmars logs we found below error message.
%C4K_SWITCHINGENGINEMAN-4-IPPPRMINTERRUPTOUTERCRC: IPP PRM outerCrcInt interrupt. valid: 1 superPortId: 0x2D lastCellAddr: 0x23DCD firstCellAddr: 0x23DCC
%C4K_SWITCHINGENGINEMAN-4-IPPPRMINTERRUPTPKTPARITY: IPP PRM pktParityInt interrupt. valid: 306112360 parity_error: 0x1 addr: 0x4
%C4K_SWITCHINGENGINEMAN-4-IPPPRMINTERRUPTOUTERCRC: (Suppressed 27 times)IPP PRM outerCrcInt interrupt. valid: 1 superPortId: 0x38 lastCellAddr: 0x39624 firstCellAddr: 0x39624
%C4K_SWITCHINGENGINEMAN-4-IPPPRMINTERRUPTPKTPARITY: (Suppressed 31 times)IPP PRM pktParityInt interrupt. valid: 306112360 parity_error: 0x1 addr: 0x4
attached the show version output
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(40)SG, RELEASE SOFTWARE (fc2)
Technical Support:
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 07-Nov-07 20:14 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11D86AF8
ROM: 12.2(40r)SG1
Darkside Revision 4, Jawa Revision 14, Tatooine Revision 140, Forerunner Revision 1.71
IND_CYP_FLR6 uptime is 3 minutes
Uptime for this control processor is 3 minutes
System restarted at 23:21:02 IST Tue Jan 26 2010
System image file is "bootflash:cat4500e-ipbasek9-mz.122-40.SG.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4510R-E (MPC8548) processor (revision 6) with 524288K bytes of memory.
Processor board ID SPE120100J8
MPC8548 CPU at 1.33GHz, Supervisor 6-E
Last reset from PowerUp
2 Virtual Ethernet interfaces
292 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Looking for some expert to help me on this as i could not find the error on any site..
Overall Rating: 2 (1 ratings)
sachinraja Thu, 01/28/2010 - 08:59
Hi Madhu
Did the switch crash ? or did you reboot the switch since you had any issues ? do you have any crashinfo files generated when the switch rebooted ? This looks a new error when compared with the existing %c4k messages... do you have support contract for this switch ? If so you can raise a tac since this is a new error message.... I ran output interpretor but didnt get any response for this message..
Hope this helps.. all the best
madhusudhan s Fri, 01/29/2010 - 03:57
Hi sachin,
thanks.. I opened a TAC for this issue.. and come to know that it is a parity error which is related to hardware issue. as per tac there are 2 types of parity error, one is hard and other soft paraty error.. if it heppen once then it is soft parity error and we can continue with existing switch.. but if heppen again which can be considered as hard parity error then we need to raise RMA for sup... in case of hard parity error the incident will reoccur and frequency of incident increases.
KDDIPH001 Tue, 07/23/2013 - 02:47
Hi All,
we encounter same problem. error message logs on WS-C4503-E with supervisor WS-X45-SUP6-E.
Jul 21 02:01:34: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 825 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/1 in vlan 2160
Jul 22 18:06:41: %C4K_SWITCHINGENGINEMAN-4-VFEL2INTERRUPT: VFE L2 Memory interrupt. array: 0, log: 6, valid: 1, addr: 0x498 parity: 1
it seems that this issue as per cisco site support is happening on C4500-E with supervisor 7L-E.
Expert advise is highly appreciated.
